mcast question
Nov 6th, 2003
I have a cat5500 with an RSM and several vlans that I'm trying to use to multicast video from an IP/TV server cluster. I think I have the switch and RSM configured properly, but the RSM won't forward the IGMP membership report packets from the client vlan to the server vlan. I have igmp enabled on the cat:
#igmp
set igmp fastleave enable
and here's relevant config from the RSM:
ip multicast-routing
interface Vlan60
description SON vlan60: User60
ip address 10.2.60.8 255.255.255.0
no ip redirects
no ip directed-broadcast
ip pim sparse-mode
no ip route-cache cef
no ip mroute-cache
mls rp vtp-domain SON
mls rp ip
standby 1 priority 100 preempt
standby 1 ip 10.2.60.10
interface Vlan120
description SON vlan120: 4th-labs
ip address 10.1.120.8 255.255.255.0
no ip redirects
ip pim sparse-mode
ip cgmp
no ip mroute-cache
mls rp ip
standby 1 ip 10.1.120.10
Rich
Harold Ritter Thu, 11/06/2003 - 14:35
  • Cisco Employee,
IGMP messages are not forwarded from one VLAN to another. You see you have configured PIM sparse-mode. I assume you have a Rendez-vous point then. Right? If this is just for a test then you could use dense mode to propagate multicast between the two VLANs.
Hope this helps.
