Warning message
CDP neighbor problem with Cisco 1721 (IOS 12.3)
I just had a new Cisco 1721 with IOS version 12.3. The problem is that the router see themself as CDP neighbor.
Is it a bug in this new IOS?
Show ver, show interface and sh cdp nei det are here.
Router#sh ver
IOS (tm) C1700 Software (C1700-Y7-M), Version 12.3(1a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 06-Jun-03 19:50 by dchih
Image text-base: 0x80008120, data-base: 0x80AFBAA0
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
Router uptime is 1 week, 1 day, 23 hours, 32 minutes
System restarted at 11:15:41 NZDT Wed Oct 29 2003
System image file is "flash:c1700-y7-mz.123-1a.bin"
cisco 1721 (MPC860P) processor (revision 0x200) with 54917K/10619K bytes of memo
ry.
Processor board ID FOC073712VS (1401315277), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Router#sh run int f0
interface FastEthernet0
ip address 10.154.140.1 255.255.255.0
speed 10
half-duplex
Router#sh cdp nei det
Device ID: Router
Entry address(es):
IP address: 10.154.140.1
Platform: cisco 1721, Capabilities: Router
Interface: FastEthernet0, Port ID (outgoing port): FastEthernet0
Holdtime : 143 sec
Version :
advertisement version: 2
Duplex: half
Router#
Georg Pauwen Fri, 11/07/2003 - 13:17
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
Hello Kevin,
I checked for a bug but there is none describing your problem. Is the entry still there after you do a clear cdp table ?
Georg
Hi, Georg
I disabled the cdp enable on that interface for last two days. After I saw you reply, then I enabled the cdp for F0 interface. Now I do not have cdp neighbor problem, I did clear cdp table, still OK.
That interface connects to customer LAN PCs. I will keep monitoring it for a few days.
Thank you very much , Georg.
Georg Pauwen Tue, 11/11/2003 - 14:09
    2017 WAN
Hi Kevin,
sounds good, I started thinking that the router might have psychological problems, seeing himself as his own neighbor :)
Georg
