Warning message
remote access on two Windows XP Boxes?
gmarogi Wed, 11/12/2003 - 12:42
  • Bronze, 100 points or more
One way to connect them is to use a LAN connection to a RAS box which supports async and DSL. There are few Cisco products which can be used. Check out http://www.cisco.com/univercd/home/home.htm .
If you want to connect them natively without a separate RAS box, then one ofthe XP machines might need to be configured with a RAS application.
