Warning message
VLAN and IPSEC
Nov 7th, 2003
When you have the same VLAN at 2 different sites. (The 2 sites have the SAME IP-subnet)
Is it possible to encrypt traffic using IPSEC between the 2 sites ?
jhaggett Fri, 11/07/2003 - 07:28
I am also curious to see how this would work :)
MMostert Tue, 11/11/2003 - 23:29
Basically when you are linking two different sites using routers I would advise to use different subnets at both locations to simplify the routing tables.
csgnm Wed, 11/12/2003 - 02:26
thanks for the suggestion but this is not the answer I am looking for.
