3.3.3 CCM log-out timer on CCMADMIN web pages
Nov 7th, 2003
Anyone know of a way to set the forced logout timer for the CCMADMIN pages? We are running multi-level admin and I suspect that may be controlling it.
When you are in any of the CCMADMIN pages, you are forced out after 20 minutes of inactivity. Any way to change that?
Brady
Jeff Garner Fri, 11/07/2003 - 12:20
It is set in IIS...
Goto your IIS Manager, Then to the CCmAdmin Web page... Click on properties of the ccmAdmin directory, then under the virtual directory tab, click the configuration button, then App options tab, you will see session timeout 20 munites...
Jeff Garner Fri, 11/07/2003 - 12:31
scratch that it looks like they are overriding it with the javascript Session.Timeout command...
bpalmquist Fri, 11/07/2003 - 14:19
Thanks for responding Jeff. I was afraid it might be in the web page. Wonder if that parameter is globally configured in a place where one could actually change it.
