NAT works on local segment only
Nov 8th, 2003
While trying to set up nat i ran into a problem here is it.
Cisco 2621 with two T1 WICs s0/0 and s0/1
with a default route to each serial interface
my config before was
s0/0=65.81.249.86/30 next hop=65.81.249.85
s0/1=65.81.249.90/30 next hop=65.81.249.89
fa0/0=65.172.227.1/24
a client connected directly to fa0/0 via crossover with this ip x.x.227.2/24 can reach the internet
then i started to setup NAT
rrg-router#show run
Building configuration...
Current configuration : 1122 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname rrg-router
no ip subnet-zero
no ip domain lookup
interface FastEthernet0/0
ip address 172.18.1.1 255.255.255.0
ip nat inside
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
interface Serial0/0
ip address x.x.x.86 255.255.255.252
ip nat outside
no ip route-cache
no ip mroute-cache
load-interval 30
service-module t1 timeslots 1-24
interface FastEthernet0/1
ip address x.x.x.1 255.255.255.0
no ip route-cache
no ip mroute-cache
shutdown
speed 100
full-duplex
interface Serial0/1
ip address x.x.x.90 255.255.255.252
no ip redirects
no ip route-cache
no ip mroute-cache
load-interval 30
shutdown
ip default-gateway 160.81.249.85
ip nat inside source list 1 interface Serial0/0 overload
no ip http server
no ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
access-list 1 permit any
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
password xxxx
login
end
rrg-router#show ip nat trans
Pro Inside global Inside local Outside local Outside global
icmp x.x.249.86:80 x.x.249.86:80 68.146.82.201:3760 68.146.82.201:3760
icmp x.x.249.86:53 x.x.249.86:53 65.125.153.9:43974 65.125.153.9:43974
icmp x.x.249.86:27316 x.x.249.86:27316 68.100.100.184:27316 68.100.100.184:27316
tcp 160.81.249.86:3891 172.18.1.2:3891 129.244.36.163:2254 129.244.36.163:2254
icmp 160.81.249.86:256 160.81.249.86:256 80.46.148.113:256 80.46.148.113:256
icmp 160.81.249.86:53 160.81.249.86:53 138.64.4.2:53 138.64.4.2:53
icmp 160.81.249.86:80 160.81.249.86:80 65.212.188.100:57381 65.212.188.100:57381
icmp 160.81.249.86:53 160.81.249.86:53 66.150.179.79:16534 66.150.179.79:16534
udp 160.81.249.86:1026 172.18.1.2:1026 204.117.214.10:53 204.117.214.10:53
icmp 160.81.249.86:80 160.81.249.86:80 65.212.188.100:57390 65.212.188.100:57390
icmp 160.81.249.86:80 160.81.249.86:80 65.212.188.100:57402 65.212.188.100:57402
icmp 160.81.249.86:80 160.81.249.86:80 65.212.188.100:57403 65.212.188.100:57403
icmp 160.81.249.86:53 160.81.249.86:53 65.126.181.101:61380 65.126.181.101:61380
icmp 160.81.249.86:80 160.81.249.86:80 65.212.188.100:57455 65.212.188.100:57455
rrg-router#show ip nat sta
Total active translations: 55 (0 static, 55 dynamic; 55 extended)
Outside interfaces:
Serial0/0
Inside interfaces:
FastEthernet0/0
Hits: 2436 Misses: 1466
Expired translations: 1307
Dynamic mappings:
-- Inside Source
[Id: 6] access-list 1 interface Serial0/0 refcount 55
it breaks. i can't reach the internet, ping or http. any suggestions? is there a way you can overload both serial interfaces?
m.matteson Sat, 11/08/2003 - 16:45
resolved. the problem was that sprint was passing packets from the 65.x.x.x and not from 160.x.x.x i overloaded to a nat pool and it works fine.
