Reporting on Wrapup States in CTIOS/IPCC
Nov 10th, 2003
Does any one know how to setup CTIOS so that we can report against the Agent's selected Wrapup state.
By default you get some dummy Wrapup, Not Ready and Logout codes. We have enabled all three for our agent. While dealing with a call the three List boxes are displayed and selections are made.
But... When you look at the Agent_State_Trace table the state changes are recorded but the ReasonCode is 0 for the Wrapup state. Not Ready and Logout states are recorded fine with the value selected by the agent.
From what I can tell, having and selecting a Wrapup code should be enough to store it in the database.
Can anyone help?
sbilgi Fri, 11/14/2003 - 12:28
  • Silver, 250 points or more
You can do Agent reporting on AW.
