Warning message
Unity 4.02 Directory Handler "Operator"
Answered Question
I have several different directory handlers setup on Unity. In the default system prompt for the direct handler it is stated, "For help press 0." I have set the caller input "If caller exits" option to go to a particular subscriber. If I do nothing, it goes to that subsciber. If I press 0, it appears to be going to the Operator call handler. This is not desired. I need it to go to the same place I'm setting for "If caller exits." How can I set where "0" takes a caller for each individual directory handler?
Correct Answer by lindborg about 13 years 9 months ago
There are actually 4 exit routes off a directory handler - for reasons that are lost in the fog of history the SA only exposed one of them. If you go out and fetch the latest Audiotext Manager (ATM) off http://www.CiscoUnityTools.com, it will let you set each exit route seperately on your directory handlers which should get you where you want to go.
Overall Rating: 5 (1 ratings)
Correct Answer
lindborg Mon, 11/10/2003 - 10:41
  • Cisco Employee,
