ISDN Integration CALL MANAGER - PBX.
Nov 10th, 2003
We have a connection between a PBX and a Call Manager using an 3660 as a H.323 Gateway, using an PRI-ISDN E1 ECMA-QSIG. Only works properly the service "A Presentation Number" in both direction.
This is we can see only the "A number" in both direction.
-Which others ISDN (QSIG) services works on this links, using E1 ISO-QSIG or ECMA-QSIG?
-When CISCO will add another features, using the 3660 as an H.323 Gateway or MGCP Gateway?
Best Regards.
smalkeric Mon, 11/17/2003 - 08:56
  • Silver, 250 points or more
I guess cisco does not support ECMA qsig, only supports ISO qsig. Also there are two versions of ECMA qsig one is kind of similar to ISO qsig.
