Accessing CMS over a VPN tunnel
Is it possible to access CMS on a switch that is on another LAN that is connected via a VPN tunnel?
For example...
I have a switch on the 172.16.20.x network that I want to be able to access the CMS on from the 172.16.1.x network.
Is it possible to do this? I am thinking that you have to be on the same subnet and VLAN in order to access the CMS so this will probably not be possible. But is there any way at all to do this? Any way to add switches with CMS from different networks connected via VPN to the same cluster?
Thanks in advance.
