Warning message
CE590 Websense integration issue.
Nov 11th, 2003
I have a CE590 which I am trying to set up as a transparent cache using a Websense server for URL filtering. Everything seems to work fine if I have Allowmode enabled but I get incomplete pages and the 'URL requested was filtered' page if I disable the Allowmode.
The Cisco instructions for setting this up are quite simple but I cannot work out what is causing this error.
Can anyone help me?
Richard.
Overall Rating: 2 (1 ratings)
owillins Mon, 11/17/2003 - 12:17
  • Silver, 250 points or more
Make sure you have selected the "Cisco cache engine" option when installing websense.
Try uninstalling and re-installing again. Get an eval key for the Content Engine Edition and check if it works.
