Warning message
External Phone number mask
Nov 12th, 2003
BAT in CCM 3.3.3 does not provide a way to update the "external phone number mask" on individual DNs. Does anyone know where this value is stored in SQL?
jasyoung Wed, 11/12/2003 - 08:35
  • Gold, 750 points or more
Find your CCM database in SQL Enterprise Manager. It will be in the form of 'CCM03XX'. If you have more than one, the highest-numbered one is usually the one in active use. The field you're looking for is 'e164mask' in the table 'DeviceNumPlanMap'. If you make changes here, you should restart CallManager afterwards.
