Warning message
Site Survey S/N Ratio
ED CARMODY Sat, 11/15/2003 - 13:52
The answer is "it depends." Cisco AIR-PCM352 cards have about a -3db better receive sensitivity at thet 11MB rate than most cards. Cisco 352 cards tend to rate shift from 11 to 5.5 somewhere around 20db, depending on other factors.
If you do a site survey, you have to know what clients you're going to have to support. I'd bet that at some point, you're going to have to support non-Cisco cards.
My recommendation is that when you use a Cisco card to do a survey, give yourself an extra 3db of wiggle-room. So, to support 11MB data rates, I survey for a 23dB s/n ratio.
But, if you have to support voice....
ED CARMODY Mon, 11/24/2003 - 18:36
Technically, no, they are not incorrect. A Cisco card *can* maintain an 11Mb datarate at 12db, but your packet loss can start to be an issue.
Many device manufacturers state that their products work satisfactorily with an SNR of 20 dB or better.
kschung Tue, 11/25/2003 - 13:02
20dB is a very good figure. For whatever its worth, that's my benchmark also. This is from experience.
kevin
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
