Warning message
how to clear counters in acl log on pix
Nov 12th, 2003
Dear sir,
I have a pix and set some ACLs on it. the ACL would logging the match times as:
show access-list
access-list outside permit tcp any host 211.156.53.18 eq www (hitcnt=1995331)
access-list outside permit icmp any host 211.156.53.18 (hitcnt=409952)
access-list outside permit icmp host 211.156.63.155 any (hitcnt=0)
I want to know which command I can use to clear the value in hitcnt. I've tried clear traffic but took no effect.
Please help me! My pix is pix-525, software is 6.0(1).
Thank you so much!
Sha
Overall Rating: 5 (1 ratings)
nihal.akbulut Thu, 11/13/2003 - 01:45
hi,
in config mode do the following;
clear access-list acl-name counters
hope this helps..
Nihal
shahaij Thu, 11/13/2003 - 18:17
Nihal,
Thank you for your help.
But my software is 6.0. It seems there is no parameter 'counters'. What should i do now, can i achieve my goal?
Thanks again!
Sha
nihal.akbulut Fri, 11/14/2003 - 01:42
I can't see any command like that , either. But when I write it, it works. maybe you can try, too.
