Georg Pauwen Fri, 11/14/2003 - 04:34
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
not sure if that is what you mean, but when you configure the framing on the interface the following applies:
POS framing defaults to SONET. The following default values are used for SONET.
s1s0 default value is 0.
J1 defaults set to host name, interface name, and IP address.
The following default values are used for SDH framing:
s1s0 default value is 2.
J1 is the path trace string. Its default setting is empty and is not configurable.
GP
