IPX inter-vlan routing
Nov 14th, 2003
We need to setup a 6509 switch to allow inter-vlan routing. The routing should handle ip and ipx.
The 6509 is installed a msfc2 with supervisor engine 1A.
My question is that, do I need to upgrade or buy anything to make ipx routing work between different vlan? Or the existing setup is ok?
Best Regards
Raymond Chow
Overall Rating: 5 (1 ratings)
ashok_boin Fri, 11/14/2003 - 06:14
  • Bronze, 100 points or more
This is from Cisco.
The MSFC—in combination with the PFC—provides 15 million packets per second (Mpps) of forwarding performance for IP, IPX®, and IP Multicast traffic, in addition to supporting multiprotocol routing for AppleTalk, DecNet, and Vines for Enterprise customers.
I think you are having PFC because you are doing IP intervlan routing. Then, it'll support, no need.
This might help...
http://www.cisco.com/warp/public/cc/pd/si/casi/ca6000/prodlit/c6000_si.htm
Regards...
Ashok.
s2193988 Fri, 11/14/2003 - 09:50
do I need the following software feature?
Part number: S6MSF2DV-12119E
Raymond
