Warning message
Single number solution for voice/fax
Nov 17th, 2003
Has anyone used a single number solution for voice/fax for Unity using:
-T.37 on ramp IOS fax gateway
-Fax Detection Feature for IOS gateway
-Unity IP FaxRouter
I'd like to know if this is possible and what, if any pitfalls, I should be aware of?
Thanks.
Manish
vmalhi Tue, 11/18/2003 - 01:49
I've been running T.37 fax, it works pretty well (both on-ramp and off-ramp).
The biggest problem I have is radius accounting- I can create stop records but not start records meaning I can't use my normal VoIP billing system to bill for fax.
Never used fax detection or unity faxrouter.
ngss Mon, 12/22/2003 - 20:32
I aslo the requirement of using Fax Detection feature using Cisco 3745 as Voice Gateway
Really appreciate if anyone had tested this feature and share the experience here.
I need your sound advice whether this is a viable solution or stick to separate voice and fax number.
I only have this page for reference.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t11/faxapp/detect.htm
SSng
