11-18-2003 07:09 AM - edited 03-02-2019 11:48 AM
Good Day,
I have such problem, i have serial interface with one E1, but the problem is i cant receive E1 totally
i just receiving 1952 instead of 2048? please can anybody tell me what is the problem is ?
here is the outputs :
gw#show controllers serial 3/0
M4T: show controller:
PAS unit 0, subunit 0, f/w version 3-101, rev ID 0x2800001, version 3
idb = 0x6280A8B8, ds = 0x6280C598, ssb=0x6280C8C4
Clock mux=0x0, ucmd_ctrl=0xC, port_status=0x74
Serial config=0x8, line config=0x200
maxdgram=1608, bufpool=48Kb, 96 particles
DCD=up DSR=up DTR=up RTS=up CTS=up
line state: up
cable type : V.35 DTE cable, received clockrate 2047212
base0 registers=0x3D800000, base1 registers=0x3D802000
mxt_ds=0x645309B8, rx ring entries=47, tx ring entries=64
rxring=0xF1E09A0, rxr shadow=0x62812924, rx_head=6
txring=0xF1E0B60, txr shadow=0x62812B90, tx_head=47, tx_tail=49, tx_count=2
throttled=0, enabled=0
halted=0, last halt reason=0
Microcode fatal errors=0
rx_no_eop_err=0, rx_no_stp_err=0, rx_no_eop_stp_err=0
rx_no_buf=0, rx_soft_overrun_err=1, dump_err= 0, bogus=0, mxt_flags=0x8
tx_underrun_err=0, tx_soft_underrun_err=0, tx_limited=1(2)
tx_fullring=546116580, tx_started=-1183781241
rx_int_count=556922015, tx_int_count=-606654699
Half-duplex hdx=0x62812670, summary:-
invalid_state=0, jigged_sig=0, invalid_timeout=0, tx_drop=0
tx_int_err=0, rx_drop=0, timer_error=0, rts_timeout=0
invalid_rx=0, tx_lost_cts=0, cts_timeout=0, late_rx=0
interface Serial3/0
bandwidth 2048
ip address x.x.x.x 255.255.255.252
ip access-group 102 in
ip route-cache flow
max-reserved-bandwidth 100
serial restart-delay 0
Serial3/0 is up, line protocol is up
Hardware is M4T
Internet address is x.x.x.x/30
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
reliability 255/255, txload 193/255, rxload 95/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 2w1d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
3502098
Queueing strategy: weighted fair
Output queue: 26/1000/64/3502098 (size/max total/threshold/drops)
Conversations 23/189/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 2048 kilobits/sec
5 minute input rate 770000 bits/sec, 1154 packets/sec
5 minute output rate 1553000 bits/sec, 2426 packets/sec
883999815 packets input, 1363370716 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
550 input errors, 529 CRC, 0 frame, 11 overrun, 1 ignored, 10 abort
1604098154 packets output, 827315952 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
5 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
11-24-2003 11:16 AM
From the output of the show controllers command, the actual speed of the line is pretty close to E1. I guess things are ok. There is another observation though. You have a high number of output drops. You probably should refer to the document at http://www.cisco.com/en/US/customer/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml
03-07-2004 02:21 AM
Hi.
E1 consists of 32 64k channels so the total data rate is 64x32 = 2048kbps, but channel 0 is used for Synchronization and Alarm etc, so the data rate that is available end to end is 2046kbps - 64kbps.
Jawwad
