Migration network
Nov 19th, 2003
i'd like to migration my network,and i musto to divide in two site.
I tried with virtual-link in OSPF but it's no good idea.
I don't want use the bridge for the tranpsort,nayone have some ideas?????
Roberto
ruwhite Wed, 11/19/2003 - 06:51
  • Gold, 750 points or more
Do you mean that you want to move your network from one physical location to another, one piece at a time? And you're trying to figure out how to have the same subnets at both physical places? If so, then the only option would be bridging.
Russ.W
rpaolet Thu, 11/20/2003 - 01:52
I studied an example in BSCI,i can use the virtual-link in ospf,but it doesn't work.
Ok,can i use trunk between 2 routers and i sue encapsulation dot1q or isl and so i use in two site the same network,because if i use the bridging the link between the 2 routers will be dedicate only for this transport.
Thanks for your response
Roberto Paoletti
