Warning message
QoS on Catalyst 6500
Nov 19th, 2003
Hello All,
got a question regarding classification/colouring on a Cat 6500 with IOS 12.1.13 (E9):
We get the output: (all classes dscp 0)
H1C#sh mls qos ip fa 3/11
[In] Policy map is COS-Test [Out] Default.
QoS Summary [IP]: (* - shared aggregates, Mod - switch module, F - install error)
Int Mod Dir Cl-map DSCP AgId Trust FlId AgForward-Pk AgPoliced-Pk
Fa3/11 1 I GOLD 0 0* No 0 1060798 0
Fa3/11 1 I SILVER 0 0* No 0 1060798 0
Fa3/11 1 I BRONZE 0 0* No 0 1060798 0
Fa3/11 1 I PLATINUM 0 0* No 0 1060798 0
H1C#
after applying the following config:
version 12.1
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname H1C
boot system sup-bootflash:c6sup22-js-mz.121-13.E9
no ip domain-lookup
class-map match-any GOLD
description high priority traffic
match access-group name SAP
class-map match-any BRONZE
match access-group name FTP
class-map match-any PLATINUM
description real time protocols
match access-group name VoIP
class-map match-any SILVER
match access-group name HTTP
match access-group name default
policy-map COS-Test
class GOLD
set ip dscp 10
class SILVER
set ip dscp 18
class BRONZE
set ip dscp 28
class PLATINUM
set ip dscp 46
mls flow ip destination
mls flow ipx destination
mls qos statistics-export
mls qos
redundancy
mode rpr-plus
main-cpu
auto-sync running-config
auto-sync standard
interface FastEthernet3/11
no ip address
service-policy input COS-Test
switchport
ip access-list extended FTP
permit tcp any eq ftp-data any
permit tcp any eq ftp any
permit tcp any any eq ftp-data
ip access-list extended HTTP
permit tcp any any eq www
permit tcp any eq www any
permit icmp any any
ip access-list extended SAP
remark classification of SAP R3 traffic
permit tcp 10.1.0.0 0.0.255.255 range 3200 3699 any
permit tcp any 10.1.0.0 0.0.255.255 range 3200 3699
ip access-list extended TELNET_SSH
permit tcp any any eq 22
permit tcp any eq 22 any
permit tcp any eq telnet any
permit tcp any any eq telnet
ip access-list extended VoIP
remark Voice over IP classification
permit udp any range 16382 32766 any range 16382 32762
ip access-list extended default
remark classification of not identified traffic
permit tcp any any
permit udp any any
permit eigrp any any
permit ospf any any
permit gre any any
Any mistakes ? Any hints ?
Cheers, Wolfgang
evanlau Wed, 11/19/2003 - 19:44
Try placing the service policy on the VLAN interface to which port fa3/11 belongs.
w.speckle Thu, 11/20/2003 - 22:48
finally we could identify the cause of the problem:
15:08:14: %QM-4-TCAM_ENTRY: Hardware TCAM entry capacity exceeded
Which is a pretty weired behaviour, because 5 access-lists do not fill up TCAM.
Currently we are investigating if it is a problem of just that test-box or a general one.
We could make it work with just one class either on a VLAN interface or on a physical one - both worked.
The VLAN int is tricky because only the initial flow-setup is routed, subsequent traffic flows are switched directly and do not pass the VLAN interface anymore ...
Many Thanks, Wolfgang
evanlau Thu, 11/20/2003 - 22:52
Shouldn't be a problem with applying it to the VLAN int. Even though the flows are 'switched directly', any policies applied to the initial packet is still applied to the subsequent packets, including your policy map (or any other policies for that matter).
w.speckle Thu, 11/20/2003 - 22:55
unfortunately I can not confirm this:
Colouring on the VLAN int ended up with no result,
(only very little hits on the access-list which identifies VLAN sourced traffic)
The same service-policy applied to a physical int worked fine ...
Wolfgang
evanlau Thu, 11/20/2003 - 22:59
This would seem to indicate that most of the traffic is contained within the same VLAN, not routed. In this case, you are correct in saying that the service policy has to be applied to the physical interface, not the VLAN interface.
Is this a correct assumption?
