Warning message
I am not able to remove crypto map SONZOGNI^@
Nov 20th, 2003
Please,show me the command to remove crypto map SONZOGNI^@ .
Command "no crypto map SONZOGNI^@" doesn't work,Router Cli response is crypto map unexisting.
The Router model is 3640.
12.0
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
boot system flash:c3640-is40-mz.120-24.bin
logging buffered 32000 debugging
no logging console
ip subnet-zero
no ip source-route
no ip finger
no ip domain-lookup
isdn switch-type primary-net5
crypto map SONZOGNI^@ 1
set peer cisco-sonzogni
match address sonzogni-encrypt
clock timezone CET 1
clock summer-time CET-SUM recurring last Sun Mar 3:00 last Sun Oct 3:00
call-history-mib max-size 200
Georg Pauwen Thu, 11/20/2003 - 10:13
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
try:
no crypto map map-name seq-num
that is, also the sequence number.
Georg
dcristoni Fri, 11/21/2003 - 00:30
unfortunately i have already tried with command "no crypto map map-name seq-num" but it didn't work.
^@ is my problem!
nihal.akbulut Fri, 11/21/2003 - 01:57
Sometimes I live the same problem, too. It's because of the hyperterminal. In some hyperterminals, when I use the uparrow to write the last command again it writes the last command but it appends ^@ characters and return.Maybe u can use a trick like that. If you first write "no crypto map SONZOGNI" end enter, after that use uparrow key. it automaticly writes "no crypto map SONZOGNI^@". maybe it makes sense.
hope it works..
dcristoni Fri, 11/21/2003 - 06:46
I tried to follow your advice but it doesn't work because my hyperteminal doesn't append ^@.
Can you give me a configuration of hyperteminal to simulate that defect?
The last solution is a reset and rewrite configuration but the router is a backbone machine and i can't do it.
nihal.akbulut Mon, 12/01/2003 - 01:15
I exactly don't know the configuration. It works that way on some XP machines by default. But if you want I can send you the hyperterm.exe ..
dcristoni Wed, 12/03/2003 - 03:13
Thanks for your help,don't worry!
Tomorrow i will erase nvram memory.
