11-20-2003 01:52 PM - edited 03-02-2019 11:52 AM
I have 2 t-1's in a router, I'm using static routes. How does the IOS decide which t-1 to send traffic over?
thanks,
11-20-2003 04:44 PM
The IOS will automatically load share over, up to 4, equal cost paths but at the session, rather than at the packet, level.
You can force it to load share on a per packet basis by disabling fast switching,
no ip route-cache
on the interface but this is not recommended as it will impact the router's performance.
11-20-2003 05:13 PM
thanks, I'm reading about all this as I go along, would CEF be of any value?
11-21-2003 06:16 AM
Yes, you want to run CEF... CEF will load share based on the source and destination addresses.
http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_technical_reference09186a00800afeb7.html
Russ.W
