DNs in partition
Overall Rating: 5 (1 ratings)
dugrant Fri, 11/21/2003 - 18:18
  • Bronze, 100 points or more
Partitions go hand in hand with Calling Search Spaces.
If you add a number to a partition, the only way a device can call that number is if the calling device has a CSS assigned to it that contains that partition.
Basically, a CSS is a list of partitions, which defines what a device can call.
For your problem, you need to create a new CSS and add the new partition to that CSS. You then need to assign that CSS to the gateway, and any other device (phone, etc) that you want to be able to call the new DN.
By default, the partition is included in all CSS's, so devices not in a partition will still be able to be called.
