Warning message
marcabal Mon, 11/24/2003 - 12:49
  • Cisco Employee,
There is not currently a CLI command for viewing the serial number.
marcabal Fri, 01/02/2004 - 12:50
  • Cisco Employee,
The Service Tag.
The Service Tag and the Serial Number are generally the same.
(Most sensors will have a smaller sticker somewhere else on the sensor with the serial number and you will see it matches the number in the service tag.)
rwassom Mon, 01/05/2004 - 04:53
The Service Tag is used for the Serial Number on IDS-4210, -4235, and -4250 appliances. All other Cisco IDS appliances should have a standard Serial Number label on the chassis.
