Warning message
Packet loss when 2950 + 3Com Router
Nov 27th, 2003
I found the packet loss issue when 2950 switch connect to 3Com Netbuilder II router directly. Any knows what is the cause?
The temporary workaround I using is add a hub in the middle to fix the problem.
Bennith.
hec-oa Thu, 11/27/2003 - 22:15
Found the cause:-
1. 3Com 10Mbps module(AUI/BNC) + AUI Transceiver cause the speed negoication problem.
Now we use the 100Mbps module(RJ45) to fix the problem,
Thanks.
