Warning message
SS7 E1 Config in 5300 GW
Answered Question
Dec 2nd, 2003
How I must configure a E1 controller of a 5300 to interconet to a SS7 switch ???
is with ds0-group and with type p7 ??
or pri-group ?
I don't find any example config for SS7 interconection, only for R2 or ISDN.
TIA
Correct Answer by pacameron about 13 years 8 months ago
Only way to terminate SS7 to an As5300 is to use an external PGW 2200 SS7 controller. You can't connect and process the SS7 signalling traffic directly on the AS5300 gateway.
You can use a AS5350 or AS5400 as an integrated SLT. Here is more information -
http://www.cisco.com/warp/public/cc/pd/ga/2200pstn/prodlit/pg220_qp.htm
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120xr/0219nomd.htm
Setting up a SS7 interconnect is a complex undertaking. You might want to do some research on the Cisco web site using the keywords 'PGW2200' 'VSC' 'SLT'
Overall Rating: 5 (1 ratings)
Correct Answer
pacameron Wed, 12/03/2003 - 03:05
  • Silver, 250 points or more
