Warning message
Database backup
Dec 2nd, 2003
I can't seem to backup database. No matter where I locate the target, I keep getting "backup failed" with no error message. Is there a particular log I can look in to find what the error is?
rmushtaq Tue, 12/02/2003 - 18:22
  • Blue, 1500 points or more
The backup directory must be writeable by the user casuser on UNIX systems. There should be a log file created under the target location.
Format--/generation_number/suite/directory/filename
Example--/1/cmf/database/cmf.db
The log file should tell you why it is failing
