RME Swim - Error code: '4159'
Dec 4th, 2003
Hi all
I am trying to run a swim job but this is failing with the error message:
<snip>
Error info code: '4159'
Message: 'Device error: the copy to/from flash operation failed'.
Probable cause: Flash copy failed with return code of copyUnknownFailure
<snip>
I am running RME 3.4 (no IDU's) on W2k SP3 - the job is going to a 1721
As far as I know device credentials are configured correctly
Does anyone know what this error message indicates ?
Any suggestions welcome
Many thanks in advance
marcjone Thu, 12/04/2003 - 03:56
NB: We've tried this on the following devices:
2610 running 12.0(3)T3
1720 running 12.0(4)T
Martin Ermel Thu, 12/04/2003 - 07:53
  • Blue, 1500 points or more
is there any free memory in flash or is it all in use? try to free up some flash memory.
regards,
Martin
marcjone Thu, 12/04/2003 - 08:10
Hi Martin - Many thanks for your reply
I don't have access to the device at the moment, however, we did some tests as follows:
We loaded a 12.1 image on a device with a local tftp server and tried to pull the image from the device to the CW server - this worked. We then loaded the 12.1 image back to the device with RME and this worked. We then loaded the 12.0 image to the device with RME and this worked also, however, after changing the image on the device to 12.0 Swim jobs again failed
So Swim works fine if the device is already running a 12.1 image, but will not work if the device is running a 12.0 train image
I am not aware of any restriction for RME with IOS images running old Cisco MIBs and I can't find a bug on this, but if Swim does not function on devices running 12.0 train images then this seems like quite a serious issue ...
Has anyone seen this issue with their own devices when running 12.0 images ?
Martin, do you think this could still be a problem with the amount of free flash ?
Appreciate your help
marcjone Thu, 12/04/2003 - 09:09
Just checked the debug from one of the Swim jobs on the 2610 and noted following flash information:
Max Flash: 8 388 608, max available Flash: 1 687 968
marcjone Wed, 12/10/2003 - 08:14
Hi all
Anyone have any other ideas as to the cause of this "Error code: '4159'" - Don't think it is a flash memory issue as the problem does not occur in devices running larger images
Many thanks in advance for any help
Kind regards - Marcus
