Warning message
CiscoWorks
Dec 4th, 2003
This is an ez question I know, but, I still would like guidance before I proceed.
I have What's up Gold 8.0 installed on a monitoring station. If I install CW 6.0 onto the same station will it seamlessly integrate itself with WUG 8.0? Or, do I need to uninstall? Is there an installation order?
I know that CW comes bundled with WUG.
mdyett Thu, 12/04/2003 - 15:12
Thank you for the lead. I checked the link, I didn't see any eval copy, do you know if they have a 30 or 45 day evaluation copy availble for download?
anil.u Fri, 12/05/2003 - 22:37
I also managed to get the same installed on my PC.
First download CW6.0, it comes with WUG 7.xx.
Secondly, install CW6.0, then re-install WUG8.0 you should'nt have problem, but don't try other way round as WUG won't start only.
Ciscoview integration was not smooth with respect to registarion of classes, do let me know in case you face the same.
BOL
mdyett Thu, 12/18/2003 - 04:51
Thanks for your reply BOL. I will try it
