Warning message
Cisco Security / RadWare
nkhawaja Sun, 12/07/2003 - 18:21
  • Cisco Employee,
You are asking about radware on the WRONG forum. This forum is for cisco Security products. RADWARE offers a range of products. So you need to specify what RADWARE product are you referring to here?
Nadeem
rkishanb Mon, 12/08/2003 - 11:33
Hello Nadeem:
Greetings and thanks for your reply-post.
First, I knew I was posting my message on the Cisco forum, and thisis precisely where I wanted to post the item. I was referring to using a Radware product as a mix with the broader Cisco networking environment. translating to: mostly Cisco devices with one or two radware devices.
Second, yes, I should have specified Radware Linkproof and that was an oversight.
Having gotten that out of the way, my question / help request remains as before -
When would a client want to use also a Radware euipment, advantages / disadvantages, Also, any links re. Best Practices, etc would be very valuable.
Hope the above helps and thanks.
kishan
[email protected]
