Warning message
Eigrp Query range control
Dec 5th, 2003
We have 5 regional router . with each Reginoal router branches are connected on point point links.
Some of the reginal router have 100 or mor then 100 bracnhes connected. routing protocol is eigrp. we are facing problem wiht Eigrp SIA. How query range of Eigrp can be controled. What about using eigrp Stub routing on Spoke router .will this will help.
Harold Ritter Fri, 12/05/2003 - 09:24
  • Cisco Employee,
You could use summarization from the remote barnches to the core. This will help greatly to reduce the SIA issues.
ip summary-address eigrp
vmiller Fri, 12/05/2003 - 10:25
  • Gold, 750 points or more
See the previous post. and yes stub routing will make a big difference.
