Frequent failure of NM-16AM module
Dec 7th, 2003
It is found NM-16AM module ports are getting failed frequently. Pls let me know anybody facing the same problem and any remedy to resolve the issue.
thisisshanky Sun, 12/07/2003 - 23:02
  • Purple, 4500 points or more
Can you type in what kind of syslog messages you are getting. Also the model of router, the IOS version ( show version/ show diag) should help in further analysis. Does the router crash often ? If so, use Output Interpreter at CCO to decode the output of the crash.
