Warning message
problems configuring Vlans on a switch
Dec 9th, 2003
I have to swicthes one WS-C2924-XL and 3524 on 2924 i dont see the command vlan database , do i need to upgrade the software to configure the ports to different vlan
on 3524 i configured a new vlan and gave a ip address to new vlan and assigined few ports to the new vlan but when i see config it says new vlan in shutdown state , how bring that vlan Up
Sridhar
prafuljaded Tue, 12/09/2003 - 13:40
On a 2924, you need to add the following in config mode.Suppose u need port fa0/1 in vlan 1.
interface VLAN1
ip address x.x.x.x y.y.y.y
no shut
int fast0/1
no shut
switchport access vlan 1
"Show vlan" will tell u the ports assigned to a particular vlan.
On the 3524, u should have "no shut" command in vlan configuration mode as above.
banalas_2 Tue, 12/09/2003 - 14:07
ON 2924 I dont see command vlan database to configure vlan 300
on 3524 i did vlan database configured new vlan 300
and assigned IP address , but still i see vlan 300 shutdown
even though i did no shut on vlan interface on 3524
prafuljaded Tue, 12/09/2003 - 15:04
There is no vlan database in 2924. U need to go to global config mode as in routers and type in the commands.
Since 3524 is an L2 switch, it can have only one virtual interface (vlan)as up. If u r having more than one vlan on your switch(other than vlan 300), then u cant bring it up. It always is in shut mode.
glen.grant Sat, 12/13/2003 - 11:51
  • Purple, 4500 points or more
Do a shutdown on Vlan 1 (default vlan) and then try a no shut on the new configured vlan . If that doesn't work go into vlan database , type vlan 300 state active . This should bring it up . Then put one of your ports into vlan 300 , switchport access vlan 300 . Show vlan and you should see this port in vlan 300 .
scott-baker Fri, 12/12/2003 - 05:18
What version of software are you running? Is the switch one of the 4Mb or 8Mb versions?
