NetBIOS over TCP ceases
msecor
I recently upgraded my 2611 routers to 12.3(5) and configured AutoQoS. All worked well for about 1 week then several sites started getting intermittant failures of the router(s) to forward NetBIOS info, for instance nbtstat -a for a distant device will fail until the router is reloaded. I'm not sure where to look to figure out what's happening. Any one have any suggestions?
gmarogi
Level 5
Level 5
You could probably check the IP connectivity. You could try some debug commands to find what is happening to the NetBIOS packets. But, before that you can check if this is a known isuse with the hardware or software version that you are using, if you have access to Bug toolkit..
