IPSEC with GRE Tunnels
Dec 10th, 2003
I need to make an IPSec Nedwork with two HeadQuartes.
On HeadQuartes I put Cisco 3725 with IOS c3725-ik9o3s-mz.122-15.T7.bin.
On client side I have c1700.
I try to configure an IPSec solution with GRE tunnels and Eigrp routing.
After configuration I have established tunnels, and a good routing table in
every site.
I have connectivity from each site to other.
My problem is that from HeadQuartes Lan I don't have connectivity to
remotes sites even from ethernet-lan router C3725 I have connectivity to
each site (in routing table I have al remote sites and I check conectivity
to remote sites ethernet-lan with ping - looks like C3725 don't forwards
pakets).
Any ideea?
Thanks in advance,
Valeriu Filipescu
prasadrp Mon, 12/15/2003 - 10:02
  • Bronze, 100 points or more
Could you please post your configs and ip route on both sides to get into depth of the above problem. I have lots of sites running GRE Tunnels within IPSEC and routing EIGRP packets across them. Most of the time I have faced problems with 2 things : MTU and bandwidth parameter of the Tunnel (default bandwidth of gre tunnnel is 9 Kbit). Since you say that the tunnel is ok, need to see the configs and ip route output.
