Newbie question? Help me,thank you.
suntianyong
My cisco 2600 router "ip input" cpu use is very high,
configration nat.
high ip input counters are caused by process-switched IP packets. You need to enable CEF (Cisco Express Forwarding). To enable Cisco Express Forwarding (CEF) on the route processor card, use the ip cef command in global configuration mode:
Router(config)#ip cef
Check if the ip input counters decrease after enabling cef.
GP
