encapsulation failed.
Dec 16th, 2003
What is "encapsulation failed"
00:36:07: IP: s=172.16.1.1 (local), d=172.16.1.2 (Dialer1), len 100, sending
00:36:07: Di1 DDR: ip (s=172.16.1.1, d=172.16.1.2), 100 bytes, outgoing interesting (ip PERMIT)
00:36:07: DDR: 45000064 04B90000 FF015CBC AC100101 AC100102 0800402B
00:36:07: DDR: 09962074 00000000 002113F4 ABCDABCD ABCDABCD ABCDABCD
00:36:07: DDR: Packet queued
00:36:07: IP: s=172.16.1.1 (local), d=172.16.1.2 (Dialer1), len 100, encapsulation failed.
00:36:09: IP: s=172.16.1.1 (local), d=172.16.1.2 (Dialer1), len 100, sending
00:36:09: Di1 DDR: ip (s=172.16.1.1, d=172.16.1.2), 100 bytes, outgoing interesting (ip PERMIT)
00:36:09: DDR: 45000064 04BA0000 FF015CBB AC100101 AC100102 0800385A
00:36:09: DDR: 09972074 00000000 00211BC4 ABCDABCD ABCDABCD ABCDABCD
00:36:09: DDR: Packet queued
00:36:09: IP: s=172.16.1.1 (local), d=172.16.1.2 (Dialer1), len 100, encapsulation failed.
00:36:11: IP: s=172.16.1.1 (local), d=172.16.1.2 (Dialer1), len 100, sending
00:36:11: Di1 DDR: ip (s=172.16.1.1, d=172.16.1.2), 100 bytes, outgoing interesting (ip PERMIT)
00:36:11: DDR: 45000064 04BB0000 FF015CBA AC100101 AC100102 08003089
00:36:11: DDR: 09982074 00000000 00212394 ABCDABCD ABCDABCD ABCDABCD
00:36:11: DDR: Packet queued
00:36:11: IP: s=172.16.1.1 (local), d=172.16.1.2 (Dialer1), len 100, encapsulation failed
00:36:12: SNMP: HC Timer 617E5A10 fired
00:36:12: SNMP: HC Timer 617E5A10 rearmed, delay = 20000
00:36:12: FastEthernet3/0: PHY 0x0, read reg = 0x1, val = 0x784B
00:36:12: FastEthernet3/0: PHY 0x0, read reg = 0x1, val = 0x784B.
00:36:13: IP: s=172.16.1.1 (local), d=172.16.1.2 (Dialer1), len 100, sending
00:36:13: Di1 DDR: ip (s=172.16.1.1, d=172.16.1.2), 100 bytes, outgoing interesting (ip PERMIT)
00:36:13: DDR: 45000064 04BC0000 FF015CB9 AC100101 AC100102 080028B8
00:36:13: DDR: 09992074 00000000 00212B64 ABCDABCD ABCDABCD ABCDABCD
00:36:13: DDR: Packet queued
kkalaycioglu Tue, 12/16/2003 - 07:10
  • Bronze, 100 points or more
I've encountered this kind of encapsulation failed messages with some frame relay misconfigurations when there's a wrong IP next hop-frame relay DLCI mapping. Back to your problem, there may be something wrong about dialer-maps. Could you send sh config?
Regards.
mmali Tue, 12/16/2003 - 21:09
Its Dialup connection using US Robotics modem.
wr t
Building configuration...
Current configuration : 1634 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Dialer
enable secret 5 $1$dJ5R$xxULE4woRAU5Nn5VvW9qj1
username Receiver password 0 ali
memory-size iomem 10
ip subnet-zero
chat-script callout ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 60 CONNECT \C
--More-- !
interface Serial2/0
no ip address
shutdown
interface Serial2/1
physical-layer async
no ip address
ip directed-broadcast
encapsulation ppp
dialer in-band
dialer rotary-group 1
dialer-group 1
async default routing
async mode dedicated
no fair-queue
no cdp enable
ppp authentication chap
ppp multilink
--More-- !
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial2/4
no ip address
shutdown
interface Serial2/5
no ip address
shutdown
interface Serial2/6
no ip address
shutdown
interface Serial2/7
no ip address
--More-- shutdown
interface FastEthernet3/0
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip address 172.16.1.1 255.255.255.0
encapsulation ppp
dialer in-band
dialer idle-timeout 60
dialer map ip 172.16.1.2 name Receiver broadcast 328
dialer hold-queue 15
dialer load-threshold 1 either
dialer-group 1
no cdp enable
ppp multilink
ip classless
ip http server
--More-- !
dialer-list 1 protocol ip permit
line con 0
line 33 40
line 66
script dialer callout
modem InOut
modem autoconfigure discovery
transport input all
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password ali
login
end
Dialer#
Dialer# sh ver
IOS (tm) 3600 Software (C3640-IS-M), Version 12.1(21), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 18-Aug-03 13:56 by kellythw
Image text-base: 0x60008940, data-base: 0x60DEE000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Dialer uptime is 28 minutes
System returned to ROM by reload
System image file is "flash:c3640-is-mz.121-21.bin"
cisco 3640 (R4700) processor (revision 0x00) with 45056K/4096K bytes of memory.
Processor board ID 15140573
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
1 FastEthernet/IEEE 802.3 interface(s)
8 Low-speed serial(sync/async) network interface(s)
8 terminal line(s)
DRAM configuration is 32 bits wide with parity disabled.
--More-- 125K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Read/Write)
8192K bytes of processor board PCMCIA Slot0 flash (Read/Write)
Dialer#
kkalaycioglu Wed, 12/17/2003 - 01:13
Haven't you got a static ip route for DDR to use. For example a static default like:"ip route 0.0.0.0 0.0.0.0 172.16.1.2"
mark-obrien Thu, 12/18/2003 - 10:56
Try the command "autoselect ppp" on line 66. Your debug output does not show a call being placed on Serial2/1, and this may be the reason why. Give it a shot.
Mark
