PIX 501 static PAT configuration
Dec 18th, 2003
I've read several related posts, but I can't quite figure out what I am doing wrong. This is my first time configuring a PIX.
PIX 501 version 6.3(1)
I'm trying to allow inbound SMTP traffic to an internal mail server. We have only a single IP address, which is bound to the outside interface of the PIX. Obviously, I want inside users to still be able to NAT out.
The commands I *think* I need are these:
access-list outside permit tcp any interface outside eq smtp
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp (external_IP) smtp (internal_IP) smtp netmask 255.255.255.255 0 0
access-group outside in interface outside
with this configuration I cannot connect (from outside) to port 25 on the internal server.
what am I missing?
Thanks in advance!
tvanginneken Thu, 12/18/2003 - 11:54
  • Silver, 250 points or more
is the 'external_IP' you use in the static command the same address as the outside interface of the PIX?
Try using this static command instead of the one you use:
'static (inside,outside) tcp interface smtp (internal_IP) smtp netmask 255.255.255.255'
Try to configure log if it is still not worken. The log message should tell you more what is going wrong.
To enable logging to a syslog server:
'logging on'
'logging host inside ip-address-syslog-server'
'logging trap debug'
Kind Regards,
Tom
jhaggett Fri, 12/19/2003 - 08:15
Your config should look like this:
access-list inbound permit tcp any host eq smtp
static (inside,outside) tcp smtp smtp netmask 255.255.255.255 0 0
access-group inbound in interface outside
So most of your config is correct with exception to your access-list.
