Warning message
using gk for intercluster calls
Dec 19th, 2003
if we use a gk for intercluster calls, do all CMs in each cluster register to the gatekeeper, or only the active CMs of each cluster register to gk?
How does this work?
Yanna
dgahm Mon, 12/22/2003 - 21:59
  • Blue, 1500 points or more
That would depend on your Call Manager Groups. If you put your intercluster trunk in a device pool that has 2 subscribers in the Call Manager Group then both subscribers will register with the gatekeeper.
