System received a Bus Error exception
Dec 19th, 2003
Hi all,
I am having problems with my 1721 going in to a boot-loop after I applied new software. I have posted the results of the boot below and and wondering what I need to do to make this thing work again!
IOS (tm) C1700 Software (C1700-K9O3SY7-M), Version 12.2(4)T5, RELEASE SOFTWARE
(fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 21-Dec-02 21:36 by cmong
Image text-base: 0x800080E0, data-base: 0x80C51BC0
=== Flushing messages (00:00:09 UTC Mon Mar 1 1993) ===
Queued messages:
00:00:42949672959: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debu
gging output.
00:00:04: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
00:00:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed
state to upFile flash:crashinfo_19930301-000009 open failed (-1)
*** System received a Bus Error exception ***
signal= 0xa, code= 0x200, context= 0x81268c98
PC = 0x801caca4, Vector = 0x200, SP = 0x81381528
System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
Copyright (c) 2001 by cisco Systems, Inc.
C1700 platform with 65536 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x67b990
Self decompressing the image : #################################################
### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
After the above is displayed, it starts the boot cycle again.
I would appreciate any thoughts!
Thanks - Ray Rockholt
kkalaycioglu Fri, 12/19/2003 - 08:03
  • Bronze, 100 points or more
I think you should get back to the older software. To perform this at first you should boot the box with ROMMON and then you can load IOS with Xmodem procedures over console connection.
For ROMMON:
http://www.cisco.com/en/US/customer/products/hw/routers/ps221/products_configuration_guide_chapter09186a008007cd0e.html
For Xmodem sw upgrade procedures:
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Regards.
rockhoro Thu, 01/22/2004 - 08:21
I ended up opening a case at the TAC and they replaced the router. Great people to work with!
Thanks for your help...
