PIX firewall & Extreme Switch - Internet Brosing problem
Dec 20th, 2003
could any one let me know the way of this --- Am facing a problem with PIX & extreme switch , When i point my Web Server default gateway to my PIX firewall inside ip address ,my browsing and email works fine , but when i point it to the L3 switch of Extreme network then no browsing , no email --- I can say it confirm that Nothing wrong with PIX configuration .... is the way we need to do something in Extreme Switch ...
Overall Rating: 1 (1 ratings)
tvanginneken Sat, 12/20/2003 - 10:18
  • Silver, 250 points or more
what is the default gateway of the extreme L3 switch? I think it should be the pix in your setup.
Tom
nkhawaja Sat, 12/20/2003 - 14:19
  • Cisco Employee,
It seems to me some arp issue. May be PIX is proxy arping for your default gateway as well.
try "sysopt noproxyarp inside"
Nadeem
azharmd Sat, 12/20/2003 - 23:11
My pix inside ip is 10.0.0.11 /16
My L3 extreme Switch is 10.0.100.1 /16
When i point my Web server Default gateway to PIX inside then browsing is fine , email is ok but
when i point my Web server default gateway to L3 switch (which all are in Same VLAN) no internet no email......
I feel there is some comapatibility issue between cisco and Extreme network .... and i need to do something on PIX or L3 switch any suggestions..
tvanginneken Sun, 12/21/2003 - 11:02
maybe you could enable logging and see what the error messages are.
To enable logging to a syslog server:
logging host inside
logging trap debug
logging on
(ps, free syslog server available at: http://www.kiwisyslog.com/)
I would also like to repeat my previous question:
what is the default gateway of the Extreme Switch?
Kind Regards,
Tom
azharmd Mon, 12/22/2003 - 04:22
yes the default gateway of Exteme Switch is PIX firewall Inside IP address
tvanginneken Mon, 12/22/2003 - 04:50
did you try to configure the syslog logging? The logging should tell you what is going wrong.
Tom
