How to configure VMS to manage keys in pre-shared key policy
Dec 21st, 2003
Hello
We are using site to site VPN between Cisco 3700 Routers. the sites has GRE tunnels and it is encrypted using IPSEC, the IKE authentication method is pre-shared keys
We are looking for VMS to allow us to manage the pre-shared keys (for example allow us to change all the keys on all our Routers quarterly without the need to log on each router and issue CLI commands).
My question is:
Did anyone implemented VMS for this purpose before, can it manage the keys in the way described above?
Appreciate your help
Ammar
vidhya Wed, 12/24/2003 - 04:49
Using the Management Center for VPN Routers in the VMS bundle, you can configure and deploy the preshared keys to the routers
mubashir Fri, 12/26/2003 - 04:23
If it is possible , then how we do it. I am stuck on that. Would you suggest a procedure or url that would guide us how to do that,
REgards
Syed
