Generating Dynamic WEB key on ACS 3.2 appliance !
Jan 3rd, 2004
Is it possible on ACS 3.2 appliance to generate a dynamic WEB Key? If YES, what is the procedure? If NO, what is needed to generate it to secure my wireless LAN?
aschiebe Sat, 01/03/2004 - 08:14
ACS doesn't generate the actual WEP key. It is generated by the Wireless AP.
ACS does provide a "session-key" which is used to calculate the WEP key (using attr #25- Class Attribute) and a Session-Timeout (#27) that the AP might use to decide it needs to generate a new WEP key. However, the config of whether to use Static WEP or Dynamic WEP depends on the WAP and the Wireless client.
See http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1100/accsspts/i12211ja/i12211sc/s11wep.htm
