Warning message
Call ID showing up as customer Billing Number
Jan 4th, 2004
I have setup a 1760 with a PRI to connect to the local Telco that is providing a bank of 25 DID's. I am using MGCP and Call Manager 3.3.3. I have managed to get the Call Display and Call ID working on inbound calls but any calls that originate from one of the provided 25 DID's get tagged with a Display of "Private" and Call ID of "XXX-XXXX" which happens to be the one DID the telco uses as a billing number for us. I've seen this before at another site when I didn't send the telco enough digits so it changed it to private and the billing number. I tried to send the telco 7 digits and 10 digits and this did not work. Does anyone have any ideas why this may be happening? Is this something I have to change on my side or does the Telco have to change something.
Here is the output from a Debug isdn q931 as you can see the "Display I" has a value and so does the "calling party number i"
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838C
Exclusive, Channel 10
Display i = 'John Doe'
Calling Party Number i = 0x0081, '403XXXXXXX'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '990XXXX'
I had the change the "plan" and "type" to "unknown" on the Gateway settings page because I couldn't get outbound dialing working unless I set these values to unknown. If I set them back to the defaults of "CallManager" I get re-order tone when I try to dial out. This is what the debug isdn q931 looks like when the gateway settings are left at default.
*Mar 1 00:54:20: ISDN Se0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0001
Standard = CCITT
Exclusive, Channel 12
Plan:ISDN, Type:National
*Mar 1 00:54:20: ISDN Se0/0:23 Q931: RX <- STATUS pd = 8 callref = 0x8001
Cause i = 0x80E428 - Invalid information element contents
Call State i = 0x01
tempvg(config)#exi
*Mar 1 00:54:20: ISDN Se0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x800
Cause i = 0x809C - Invalid number format (incomplete number)
Any Ideas???
Ryan
I also have seen what you describe while I was testing between our CCM and our PBX (Nortel SL-100) while trying to get Name Display working. This was back when we were on 3.1(3). I can't remember the exact fix. Could you provide more info on how the gateway is defined on CCM? My VG200 is set to:
Called Numbering Plan = Unknown
Calling Numbering Plan = Private (I think unkown would be fine)
Number of digits to strip = 0
Caller ID Dn = 30776XXXXX (we use 5 digit dialing)
josegre Wed, 01/07/2004 - 05:46
Where do i configure this screen, on the CCM or in my gateway?
ryan_oconnell Wed, 01/07/2004 - 11:01
Here is the Detail you requested
PRI Protocol Type* -- PRI NI2
Protocol Side* --- User
Channel Selection Order* Bottom Up
Channel IE Type* Use Number when 1B
Delay for first restart (1/8 sec ticks) 32
Delay between restarts (1/8 sec ticks) 4
Inhibit restarts at PRI initialization Yes
Enable status poll Yes
Call Routing Information
Inbound Calls
Significant Digits* 4
Calling Search Space < None >
AAR Calling Search Space < None >
Prefix DN
Outbound Calls
Calling Party Presentation* Allowed
Calling Party Selection* Originator
Called party IE number type unknown* Unknown
Calling party IE number type unknown* Cisco CallManager
Called Numbering Plan* Unknown
Calling Numbering Plan* Cisco CallManager
Number of digits to strip* 0
Caller ID DN 403XXXXXXX
SMDI Base Port* 0
PRI Protocol Type Specific Information
Display IE Delivery Yes
Redirecting Number IE Delivery - Outbound Yes
Redirecting Number IE Delivery - Inbound Yes
Send Extra Leading Character In DisplayIE*** Yes
Setup non-ISDN Progress Indicator IE Enable**** No
MCDN Channel Number Extension Bit Set to Zero** No
Send Calling Name In Facility IE Yes
Interface Identifier Present** No
Interface Identifier Value** 0
