Warning message
Cisco 3640 PBX Gateway - E1 PRI, no voice ports
I have a Cisco 3640 and would like to connect it as a ISDN/PRI gateway to MD110 PBX. According to Cisco VOIp gateway configuration guide: ( http://www.cisco.com/application/pdf/en/us/guest/products/ps278/c1237/ccmigration_09186a00800e6e6c.pdf
) I should be able to use Channelized E1 module in order to interface with the MD110 PBX. My configuration, IOS and hardware configuration match or exceed the guide. However no voice port "voice-port 1/0:15" is created and consequently I can not configure a dial-peer ("dial-peer 7", interfacing with PBX). Voice ports 3/0/0 – 3/1/1 are created as expected (FXS and FXO cards) My hardware/software is as follows: 1 NM-1FE2CE1B
1 VIC2FSO
1 VIC2FSX
IOS v.12.2(2)T
Am I missing something or I should forget about the NM-1FE2CE1B module and go straight to NM-HDV type of solution?
Richard
Show version output:
Router#sh ver
IOS (tm) 3600 Software (C3640-JSX-M), Version 12.2(2)T, RELEASE SOFTWARE (fc1) TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sun 03-Jun-01 00:28 by ccai
Image text-base: 0x600089A8, data-base: 0x616C4000
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
ROM: 3600 Software (C3640-JSX-M), Version 12.2(2)T, RELEASE SOFTWARE
(fc1)
Router uptime is 0 minutes
System returned to ROM by reload
System image file is "flash:c3640-jsx-mz.122-2.T.bin"
cisco 3640 (R4700) processor (revision 0x00) with 59392K/6144K bytes of memory. Processor board ID 07991029 R4700 CPU at 100Mhz, Implementation 33, Rev 1.0 Channelized E1, Version 1.0. Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). TN3270 Emulation software. Primary Rate ISDN software, Version 1.1. 1 Ethernet/IEEE 802.3 interface(s) 1 FastEthernet/IEEE 802.3 interface(s) 32 Serial network interface(s) 2 Channelized E1/PRI port(s) 2 Voice FXO interface(s) 2 Voice FXS interface(s) DRAM configuration is 64 bits wide with parity disabled. 125K bytes of non-volatile configuration memory. 32768K bytes of processor board System flash (Read/Write)
My show running output:
Router#sh run
Building configuration...
Current configuration : 1405 bytes
version 12.2
no parser cache
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Router
logging rate-limit console 10 except errors
no logging console
enable secret xxxxxxxx
ip subnet-zero
no ip dhcp-client network-discovery
isdn switch-type primary-net5
call rsvp-sync
controller E1 1/0
clock source internal
pri-group timeslots 1-31
controller E1 1/1
interface Ethernet0/0
ip address 10.21.121.121 255.255.0.0
half-duplex
interface Serial0/0
no ip address
shutdown
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
isdn T203 30000
isdn T310 60000
isdn bchan-number-order ascending
no cdp enable
ip classless
ip http server
snmp-server manager
voice-port 3/0/0
voice-port 3/0/1
voice-port 3/1/0
voice-port 3/1/1
dial-peer cor custom
dial-peer voice 9 pots
destination-pattern 1111
port 3/1/1
dial-peer voice 10 pots
destination-pattern 1112
port 3/1/0
dial-peer voice 7 pots
destination-pattern 7...
direct-inward-dial
prefix 7
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
thisisshanky Mon, 01/05/2004 - 07:13
  • Purple, 4500 points or more
The module that you have is not a voice module. You should use a NM-HDV with a VIC-1MFT-E1 or VIC-2MFT-E1 card. The NM-HDV can also take DSP chips for handling calls.
