Warning message
VPNC3000 - no HTTPS login possible
Jan 5th, 2004
I try to connect to a VPNC3005 via HTTPS protocol after initial configuration, but it doesn't work. I had this problem already two years before. I could solve it when I deleted the certificate of the VPNC once an generate a new one. I try to do this in the same manner but I can not find where to delete it. Can you give me an idea where I can delete it?
edmonds_robert Mon, 01/05/2004 - 12:16
If you're talking about the one in your browser, and you're using Internet Explorer, go to TOOLS, then the CONTENT tab and select CERTIFICIATES. Then go to the TRUSTED ROOT CERTIFICATES tab and delete the appropriate one.
If you're talking about the one generated by the VPNC, if it's like the 3030 (not sure, never used the 3005), go to ADMINISTRATION and then CERTIFICATE MANAGEMENT.
