Problem wih route-map command for Nachi and IOS
I have a Cisco 7507 router with IOS 12.2(8)T4 for our network that will replace a 7206. The router is used on our network border to our Internet carrier. I duplicated the configuration from our working and existing 7206. The configuration included route-map statements (see below) to stop the Nachi virus from the Internet. When I have the route-map policy for Nachi configured on the 7507 we have problems with some upper layer apps, such as ehello in sendmail, NNTP and DNS synchronization. When the policy is removed all works fine. I tried another version of the IOS on the 7507, 12.2(8)T10 with the same problem. I can try an even newer version of the IOS but does anyone know of an issue with the route-map policy (for Nachi) on the 7500 IOS?
route-map nachi-worm permit 10
match ip address 110
match length 92 92
set interface Null0
interface Serial6/0/0
description ***Internet***
ip address 255.255.255.252
encapsulation ppp
ip route-cache flow
no ip mroute-cache
ip policy route-map nachi-worm
serial restart_delay 0
no cdp enable
Thanks for any help.
Jeff
vmoopeung Fri, 01/09/2004 - 12:05
  • Bronze, 100 points or more
this might be because of is a bug "CSCdp83614" in the IOS for 7507 prior to 12.1, it says the length used in the "match length" command has to match the IP length + ethernet
header (14 octets).So if you want to match IP packet with a length of 92 bytes,
you should configure :
"match length 106 106."
Try this out check whether it works .
check in the bug tool kit for more information.
