01-07-2004 08:30 AM - edited 03-02-2019 12:43 PM
I have set up per packet load sharing to a new office we opened up, two T-1's connecting the two sites. It looks as if the paths do not show as equal, they are both 1.544 private lines. The out put of show adjacency detail shows 1 line at 22 and one line at 16. Any help?
Serial0/0 is up (if_number 4)
Internet address is 10.1.101.5/30
ICMP redirects are always sent
Per packet loadbalancing is enabled
IP unicast RPF check is disabled
Inbound access list is not set
Outbound access list is not set
IP policy routing is disabled
Interface is marked as point to point interface
Hardware idb is Serial0/0
Fast switching type 7, interface type 56
IP CEF switching enabled
IP CEF Fast switching turbo vector
Input fast flags 0x0, Output fast flags 0x0
ifindex 1(1)
Slot 0 Slot unit 0 VC -1
Transmit limit accumulator 0x0 (0x0)
IP MTU 1500
Serial0/1 is up (if_number 5)
Internet address is 10.1.102.5/30
Hardware idb is Serial0/1
ifindex 2(2)
Slot 0 Slot unit 1 VC -1
IP MTU 1500
Serial0/0 is up, line protocol is up
Hardware is PQUICC with Fractional T1 CSU/DSU
Description: Connected to Level3
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 3/255
Serial0/1 is up, line protocol is up
Description: Connected to Level3_T1_2
reliability 255/255, txload 48/255, rxload 3/255
IP Serial0/1 point2point(22)
3729123 packets, 2387858739 bytes
FF030021
CEF expires: 00:02:17
refresh: 00:00:17
IP Serial0/0 point2point(16)
40307 packets, 2982478 bytes
FF030021
refresh: 00:00:17
01-08-2004 06:35 AM
I'm not certain the 22 and 16 have anything to do with the packet counts over the interfaces, or the percentages used, etc?
The packet counts do look off, but are those numbers there from when you were doing per source/destination pair load sharing? I would clear the counters, or make a note of where they are now, and see how it comes out later. Of course, I wouldn't use per packet load sharing in the first place, but that's another issue....
Russ.W
