Warning message
UNITY TTS - How do I point it to the right mailbox?
Answered Question
Perhaps a silly query but how do I direct UNITY to my subscriber's inbox on a *different* exchange server. We are not using the exchange server on UNITY for email but we want to enable text-to-speech.
Please advise - thanks!
Correct Answer by kechambe about 13 years 7 months ago
A Unity subscriber can't be associated with more than one Exchange mailbox -- I think that maybe you are trying to do that but I can't tell for sure. The email needs to be in the same mailbox associated with the Unity subscriber, the Unity server must be licensed for TTS and the subscriber class of service must all it to use TTS. Unity can't look for voicemail in one mailbox and email in another -- that just isn't how it works.
The mailbox being on a different server doesn't mean that Unity can't service it. Assuming you have Exchange 2000 or 2003 you can important the mailbox as long as it is in the same Org in to Unity. If you have Exchange 5.5 they need to be in the same site within the same Org.
Hope this helps...
Keith
Overall Rating: 5 (1 ratings)
Correct Answer
kechambe Wed, 01/07/2004 - 22:20
  • Gold, 750 points or more
Hope this helps...
Keith
