Warning message
Prevent Forwarding calls off-net
Jan 8th, 2004
Running 3.3.3sr(1); My client is wanting to prevent their users from forwarding calls off-net. I cant think of any way to pull it off. Is it possible?
Thanks in advance!
Craig
cbelcher Thu, 01/08/2004 - 08:15
I got it! Just a calling search space issue!
cb
green-robert Thu, 01/08/2004 - 09:14
Craig, this is easy to do....I’m sure there are other ways but this one works for me.....
Create a Calling Search Space, Call it something like Internal add only partitions that can NOT call off net. Worst cases add nothing to it. (Not recommended)
Now go to the Directory Number Configuration page for the phone in question, in the Call Forward and Pickup Settings add the Internal CSS to the CFA/CFB/CFNA accordingly. Update phone.
Remember if there is a need for any of the CFA/CFB and or CFNA need to go off net you may have to find another way or create a better CSS that will fit your need.
Good luck
Rob
